Still rough as the baterai placement isn't finalised as the tools weren't adequate
The 20 inch conundrum, this one is 406 so had to buy a 406 tyre and tube, got a hub ebike kit, and actually the dropout had a bit of metal so had to "sand" it so the hub wheel can go in. There was also probem with the brake rotor as 140 cm hit the hub kit so had to exchange with the 160 cm rotor at the front.
All controllers are in this bag,
Got a display, with assist level, speed, distance, time and temperature. Also have throttle, needed when starting in difficult situations. The company and guy who installed it said the kit has some waterprrof, so a little rain wouldn't be a problem, but don't throw it into water and don't leave it wet
The pedal assist kit is on the bottom bracket, Compared to other models, I find the power surge in the kit isn't as sudden. It starts low and then gets high. so if I et the level assist to 100 watts, it won't immediately start at 100 watts (which feels like you're pulled suddeny), but it increases from 0 to 100 in a couple of seconds
Baterai place still not fixed. so had to strap it at the back with two tube. got a big one for 40-80 kms (40 kms probably, as sydney is hilly, so eat the batteries more). At first was thinking of using a backpack, but then found strapping it at the back f the seat doesn't affect baance so much and is easier.
cost was 2080 AUD, around 1418 USD with installtion, as I had the guy from the company to install it. helped a little bit and learned there are so many little things that might make a straightforward ebike kit installation not so straightforward, little things but it takes your time so much
