It's a deal but thats just a starting point, you might have to add another hundred pounds or so before the finish.
don't blame me if 400lb perez leaves you in the dust when we head back down the mountain
Duh - thanks - guess I'm stupid and tired - a bad combination.don't use the game itself. go onto the zwift website and look under your profile setting for the connections tab
using the zwift test app it says I need an upgraded graphics card and I'm on the absolute minimum memory (4gb) . Is this going to cause major problems?
Kickr Snap arrived tonight...
The skewer supplied with the unit isn't long enough to do the job on the V20. The fancy DT Swiss skewer I use is incompatible with the Kickr Snap mount.
Now what? What skewer do y'all use...and where do I get one?
It's 135mm, but a standard 135 skewer is too short (the 'double thickness' V20 dropouts add ~10mm...I'm guessing). I think the skewer they provided is 130mm. It looks like Wahoo sells a 142mm 'adapter' skewer that might work. I'm going to call them today. I would like to have both ends steel (rather than aluminum or plastic) as they take a pounding.Is your wheel 130mm or 135mm spacing ?
https://www.amazon.com/dp/B00SQXMZG0
https://www.amazon.com/HUB-AXLE-SKEWER-ACTION-REAR/dp/B001CC5ZF0
Figures you would find one with yer name on it.
I had looked at that one but wasn't sure the QR end would fit the Kickr Snap.
I talked to the folks at Wahoo Fitness...but no joy. It looks like they have an adapter that would work but the guy I talked to didn't really sound like he understood anything about it at all...and offered no assistance other than to say he was sorry that they didn't have a skewer that would work.
Ok, I have an interim fix in place. It will work until I find the time to go for a 'better' option. I found a 135mm skewer (the original that came with the V20, I think) which, while it isn't perfect (only has about 3 threads engaged in the nut), will work until I find a 140+ skewer. The lock-down lever (wide aluminum) just barely fits into the Kickr socket...it is really designed around the old style metal levers. My "riding" skewer is the 145mm DT Tandem, which fits the bike perfectly but the lever is too wide to fit the socket on the Snap.
I hadn't thought about installing a non-disc wheel. Duh. I have several...but nothing that will take my 11sp cassette. My preference is always going to be "what I normally ride" vs something special for the trainer. I think finding a decent skewer will be the best bet. I certainly can make my own out of some all-thread and a couple of nuts. I think I found that stuff when I was originally looking to solve for the 135mm skewer problem.
Thanks for the help, y'all. I can always count on the tribe to steer me in the right direction!
Yup, I applied same logic. It was nice and solid and will work until I apply a more permanent solution.I think minimal thread engagement on a trainer can be ok as long as you don't tighten it to the point of stripping those few threads. Just snug it up and then when you mount it in the trainer the trainer is going to lock everything in place even more so.
I went thru some updates but not sure it was firmware specific to the Kickr Snap. I'll be sure to check this evening. Thanks!Make sure your trainer has updated firmware as brand new units can come with some very old firmware.
