I am guessing that it is green?That is my other bike.
Mine is more dirty than yours. And that one does not even have mudguards. Mine does not fold. It is one of the earliest made. I think that when I ordered it the production line was not set up. Unlike the one in the picture, mine has disk brakes, a Rohloff and Meks forks. I think they were all new ideas at the time. Indeed it is a wagon. It has the biggest Radical bags. I have carried massive amounts of stuff. My Grasshopper does not fold but my Silvio bends in the middle.benphyr said:but probably dirtier
It is ‘bent through and through.Mine is more dirty than yours. And that one does not even have mudguards. Mine does not fold. It is one of the earliest made. I think that when I ordered it the production line was not set up. Unlike the one in the picture, mine has disk brakes, a Rohloff and Meks forks. I think they were all new ideas at the time. Indeed it is a wagon. It has the biggest Radical bags. I have carried massive amounts of stuff. My Grasshopper does not fold but my Silvio bends in the middle.
I ACTUALLY agree with you, about the tailbox behind the head!!!!@Frito Bandito waterbag in the frame would be a pita.
if in there all the time, pita to clean.
if not in there all the time pita to take in and out unless access hatch, best spot would be thru seat.
when you consider that a good tailbox makes the bike faster, hard to justify.
BUT, may i suggest that you have exactly what you are looking for if you redo your little plastic triangle to start at your seat edge, go down to your lower rear stays, go under and then back up to the other seat edge. use some formable plastic or thin abs and a heat gun, and make sure you close up the back, and now you have created a great storage bin and made the bike more aero. if you really want to make it more aero and hold a whole weekends worth of stuff bring the plastic back to a straight duck taillike the back of a velo. i have looked at doing some of these things in both aluminum and plastic (not carbon, because it is utterly unnecessary) but have not had the time do make them (time is my enemy) beyond some small heating and bending tests. (i really need a second v20 to do my mock ups on.)
I planned on doing about 100km today but after about 35-40km my headrest fell off.
I backtracked to pick it up and even found both screws. As you can see, I glued it back on after it fell off the first time.
I stopped the ride and went to the DIY store to see if I could come up with something at least more durable. If it was more comfortable also then that would be great. I found a 10cm x 10cm block of thickish rubber and a 10cm x 10cm foam pad. I rounded off the corners of the rubber sheet with a pair of scissors then connected it to the suspension headrest with velcro.
I then connected the foam pad to the rubber sheet with velcro as well.
Those are HUGE Rudy! They look like cannons sticking out hahaha.
