I actually find the V20 very fast through corners, but with a catch..... I find through smooth, open corners where you know there is nothing coming the other way you cannot see (or a stick or rock, or pothole), you can set the V20 up for the corner, and go through it as quick as a DF.... quicker if it is a pedalling corner. The issue I find with the V20 is many mountain descents are rougher road and blind so you can't see if there is something on the road on the other side of the corner. On a DF you can move your weight, adjust your line and brake. On the V, you are committed with the bike leaned over and your weight to the inside. You are already fully laterally loading the tyres so can't really brake much without reducing the lateral load which is difficult without getting you weight more central on the bike. Maybe this is something more common in the hills where I live in Sydney. The roads are a bit rough. They wind switchbacks through the bush so you can't see the corner exit or anything beyond the entry. They are around 5-10%, so you easily hit 50-60kph between corners. I have experienced similar in riding DF bikes in the alps in Europe.
I did a race at a car race track. There was one corner we needed to brake for on a bike. I was racing against mostly DFs. I was generally going through that corner >5kph quicker than the DFs. Because I did the same corner many times that day and knew the road was clear so I could commit.
