Mathew Fy
GRU
I carry extra cleat screws in my bag. Also, extra derailleur hanger, boom clamp bolt, tape, tire repair stuff. Of course, if I need to use any of these, that time trial effort won’t be recorded.Failure
Also be careful with homemade hardware for which there is no stress, fatigue, or corrosion cracking analysis. That is quite the offset, does that really help? The hardware vendors do all this analysis and testing to protect the brand and prevent being sued. I had a beautiful Di2 derailleur wrap around the cassette once after over 15000 miles of flawless operation all because of a fatigue crack in the hanger likely from my sweat adding to the crack growth. So even carefully vetted hardware can go wrong.EVERYONE, it might be time, as we near the half way mark of the competition, to check your equipment. Oil/wax the chain, charge all equipment, replace batteries and bathe
Larry, would you mind if I try your shifted cleat idea? I have some 4mm carbon fiber laminate board that should work just fine. I can bond some extra stiffeners where the three holes and all the bending stress is located in the middle.Glad you are OK Ken, those adapters look so familiar!![]()
It did help me with hot foot when riding long rides.Larry, would you mind if I try your shifted cleat idea? I have some 4mm carbon fiber laminate board that should work just fine. I can bond some extra stiffeners where the three holes and all the bending stress is located in the middle.
Matt is my new friend to ride with. You are prepared.I carry extra cleat screws in my bag. Also....
Not as much as this guy:You are prepared.
@trplay Do you keep all those tools handy during the WTRL TTT? I could have used some tools last week. A tune up to the engine would have been good!Not as much as this guy:
https://forum.cruzbike.com/threads/how-good-are-patches.12877/page-2#post-154170
My results were progressing quite well until the temperature started rising (that is my excuse anyway). The rides have gone from temps of 68 to 77 degF and I have gotten slower. This week the lowest temps are about 82 degF so I will try to ride with crushed ice in a bag on my chest to see if it helps.I wonder who else is ending up with their efforts grouping together within a very tight window.
Wow - I wish it would cool down to that here on Hilton Head Island. 5am in my garage is 84 degrees and 80% humidity!My results were progressing quite well until the temperature started rising (that is my excuse anyway). The rides have gone from temps of 68 to 77 degF and I have gotten slower. This week the lowest temps are about 82 degF so I will try to ride with crushed ice in a bag on my chest to see if it helps.
Jason, I’m not anywhere near peak shape and I’ve had four attempts with a grand total of 15 sec difference between them (the last one was 13 sec faster). So, yeah - tight grouping. I’m hoping to see some more 5-10-15 second improvements in the next few weeks. Might throw on a rear wheel disc cover if I get desperate.I wonder who else is ending up with their efforts grouping together within a very tight window. I've been plateaued within the same dozen seconds and couple watts for the last month or so. I'd be ecstatic if it wasn't for that I'm not going to consistent but it's just a limit I've hit
Keep it up everyone, we are approaching the halfway point.
Great encouragement to everyone Jason - Thanks for that!I wonder who else is ending up with their efforts grouping together within a very tight window. I've been plateaued within the same dozen seconds and couple watts for the last month or so. I'd be ecstatic if it wasn't for that I'm not going to consistent but it's just a limit I've hit
I've been at the same FTP for about 5 months. I'll admit, it's kind of frustrating. I was hoping that the training schedule I had was going to be enough to get me up to 4.0 w/kg, but it looks like it won't. I think after this TT series is over I'll need to switch into an interval program, since I'm probably not getting enough training above FTP.I wonder who else is ending up with their efforts grouping together within a very tight window. I've been plateaued within the same dozen seconds and couple watts for the last month or so. I'd be ecstatic if it wasn't for that I'm not going to consistent but it's just a limit I've hit.
Chris, work in some intervals right into your TT. (I did that last week and I only ended up 1 sec under my PB). Use your garmin or some other head device to collect and average your power when you are on the Lollipop course. Do over and unders (ever minute) or something similar the entire TT and see what you come up with. That will give you some good time above your FTP to broaden your horizons.I've been at the same FTP for about 5 months. I'll admit, it's kind of frustrating. I was hoping that the training schedule I had was going to be enough to get me up to 4.0 w/kg, but it looks like it won't. I think after this TT series is over I'll need to switch into an interval program, since I'm probably not getting enough training above FTP.
Chris, another idea I had that would be easier is to create a workout in Zwift for the over and unders: for you, something like repeat 15x (300W for 1 min, 350@ for 1 min). Run it in ERG so you trainer will make you meet the wattage, plus you won't go over it by much. Start the workout just before you pass the start of the Lollipop segment start. That would give you 15 min of time above you FTP.I've been at the same FTP for about 5 months. I'll admit, it's kind of frustrating. I was hoping that the training schedule I had was going to be enough to get me up to 4.0 w/kg, but it looks like it won't. I think after this TT series is over I'll need to switch into an interval program, since I'm probably not getting enough training above FTP.
